OVER THE YEARS I’ve become increasingly fed-up with having to go outside to the pitch bollard to reconnect the electricity after either I or my wife has caused it to trip out because we’ve switched on too many mains appliances at the same time, writes Ron Horniblew.
My irritation finally reached the point at which I decided to find some way of overcoming the problem, and eventually did. All I had to do was fit a small fuse box, which would take one miniature circuit breaker (MCB), in the lead between the mains input socket and the caravan’s consumer unit.
Flexible solution
In addition to the fuse box, I also bought one 6A, one 10A and one 16A MCB. Now, when we arrive on site, I ask what the amperage on the pitch will be, and fit the appropriate MCB. If the circuit is overloaded, the MCB trips out. I then switch off the last appliance we had turned on — the one that caused the overload — and flick the MCB back on.
The only problem I have is on those few sites that provide less than 6A. When I do stop on them, I make sure that we use gas instead of mains electricity for boiling the kettle and heating the water. Since fitting the fuse control last year, I am pleased to say that it has worked like a charm!
To find out how Ron fitted his MCB fuse control panel, click here.
