There’s an art to getting the right towcar to match your caravan – or the other way round. Here’s how to do it.
Need a new towcar? Match it to your caravan safely
● First, establish how heavy your caravan is – find out its MTPLM (maximum technically permissible laden mass).
● Any caravan you buy should weigh no more than 85% of your car, so take your caravan’s MTPLM and divide by 0.85. This will give you a target kerbweight for your car. The 85% recommendation exists
because in the event of a snake your car needs to be heavier than the caravan to avoid a ‘tail wags the dog’ situation. Never tow anything heavier than the car.
● Your caravan must not exceed the car’s maximum towing weight (the most that the car manufacturer says the vehicle can tow), or you risk breaking the law. Beware: in some cars, it’s less than the kerbweight, and sometimes less than its 85% weight.
● Be aware of the car’s gross train weight (GTW) too – the maximum load the vehicle manufacturer says it can tow when it is fully laden. It is a combination of the car’s maximum gross weight (MGW) and the maximum weight of trailer it is allowed to pull. If you passed your driving test after 1 January 1997, you’ll need to sit an additional test to gain licence categories B+E if your car’s MGW is up to 3500kg and you want to tow a caravan with an MTPLM of over 750kg.
● Noseweight. Your car will have a maximum noseweight limit (the maximum downward force the car manufacturer will allow to be exerted on the towball). Try to load your caravan so that it comes close to, but does not exceed this figure.
● Choose the right engine. Diesels often make better towcars than petrol-engined cars because they have more low-down torque (pulling power at low revs) than petrol cars. They’re also more efficient, they emit less carbon dioxide and some have particulate filters to trap sooty
emissions, too.
Want a new caravan? Make sure that your car can tow it
● Multiply the car’s kerbweight (you’ll find it in the handbook) by 0.85. This figure is 85% of your car’s kerbweight and is the most your caravan should weigh when fully laden (see above for an explanation).
● Noseweight. Your caravan has a maximum noseweight limit, too, and it shouldn’t be exceeded. Reconciling the car and caravan’s noseweight can be tricky but is vital for safety.
TOP TIP
For an idea of which cars are the best, our Towcar Awards is a rigorous testing programme conducted annually by Practical Caravan, our sister publication What Car?, and the Camping & Caravanning Club. The results are published every August.
TOP TIP
The most stable outfit match is a larger, heavier car with a smaller, lighter caravan. It makes a good starting point from which to achieve a good, solid pairing.
For more information
Practical Caravan Email practical.caravan@haymarket.com or phone 020 8267 5629 for advice.
Towsafe outfit matching service Web www.towsafe.co.uk.
What Car? (for full reviews of every new car tested) Web www.whatcar.com
The notion of using the MTPLM
The notion of using the MTPLM is an assumption that everyone that tows a caravan is going to load it to the Gunwalls,WRONG (my personal opinion).There are many people out there that have been driven(parden the pun)to getting rid of perfectly good & capable tow-cars because of over enthusiastic and ill-advising caravan sales persons,often in an attempt to cover their backs and protect their employer (The XYZ Caravan Company).My own situation is a perfect case in-point.To start with the Kerbweight of my car on the TowSafe site is wrong by a large margin,the car is a very specific year/model spec.The car was made 2yrs after the EU Directive for the definition/explanation was implementer,.Our caravan has an MTPLM of 1750kgs and a MiRO of 1426(confirmed as 1440kgs).My car has a Max Tow of 1600kgs and provided I do not exceed that and do not exceed my cars train weight I therefore am within my Gross Train Weight (Car & Caravan).Also the distribution of the respective car/van loads across the axles (all four)must be correct.Provided all of that is observed and maintained then the MTPLM of 1750kgs as the deciding/starting point does not come into the equation.Our van is a 2001 Elddis Crusader SuperSirocco and is used as a Luxury 2berth Twin Axle.Under utilised on weight potential!,YES.Legal YES.Provided I do not exceed the legal limits; Insured YES.
Ignorance, can be Bliss,It is No Defence & not an excuse,Stupidity can be expensive and when combined, they can be disastrous.
Where is the spreadsheet
Where is the spreadsheet produced by Geoff Hancock which PC were putting on the website (page 10 October 2010 magazine)? I haven't found it!
