Caravan covers range in price from about £50 for a universal-fit, waterproof (but non-breathable) model, to £500 or so for a bespoke cover, handmade in quality, breathable fabrics to fit your van precisely.
The best caravan cover will protect your tourer from the elements for many years, allowing damaging moisture to escape through its breathable construction, and stopping any precipitation getting in. They also protect against harmful tree sap, bird muck and road grime… plus, they keep annoying and difficult-to-remove black streaks at bay, something that can otherwise be a nightmare to shift when you’re cleaning a caravan.
Suppliers of bespoke caravan covers
The UK’s two biggest manufacturers in the bespoke caravan covers market are Specialised Covers and Protec Covers. Both companies have decades of experience in making high-quality, made-to-measure covers, and they have similar processes for specifying and ordering your cover.
To find out how the process works, we followed two bespoke-cover guinea pigs, Andrew and Sally, who needed to protect their new, luxury Adria Alpina 623 UL Colorado from the elements.
Choose your bespoke caravan covers
It’s easy to see why your caravan needs a cover. If you are looking for a top-quality, handmade cover for your tourer, you’ll be able to find all the information you need to make your choice online.
1. After watching numerous YouTube videos on the subject and exploring just as many websites, Andrew decided that a Specialised Covers’ caravan cover best suited their specific needs (other brands that offer bespoke covers include Protec and more).
2. In terms of Specialised’s website, you need to specify the year, make and model of your tourer and the colour of the cover you want. Specialised has almost all caravan makes and models on file, but if you don’t find yours there, you can speak to customer services.
Basic covers that require no modifications can be ordered in seconds, but if you need your cover to house a caravan accessory, say a roof-mounted air conditioning unit or an aerial (see: the best caravan TV aerial if you’re after one), you can add the detail in the ‘Customisation’ section online.
3. Andrew and Sally have a solar panel fitted on the roof of the Adria, so Andrew took measurements and photos and provided a sketch.
4. These pictures were then added to their order.
5. Once Specialised Covers has your custom order, it will be sent to the design team, who use computer-aided design software to add your specific requirements on a 3D model. They then create a 2D template, which is sent to the production line.
6. The template designs are now received by the computer-controlled cutting machines, which cut them out of the required cover fabric, with accuracy to a fraction of a millimetre. These machines are also designed to minimise waste, by getting as many cover sections as possible out of each roll of material. This improves efficiency and helps to keep costs down.
7. Once they have been cut out, the sections for each bespoke caravan cover are bundled up and sent to the stitching department.
8. Here, operatives will turn what looks like random acres of fabric into a recognisable caravan cover, double-stitching all of the seams for maximum strength and durability.
9. Sewing a full caravan cover really is a massive task! The Adria cover was specified with a transparent plastic window, to allow the solar panel to work with the cover in position. The added piece was carefully stitched into the cover at this stage.
10. Finally, buckles and straps are stitched onto the cover. Once the cover has been completed, it goes to the Quality Control Department and then to Dispatch. Typical lead times are two weeks.
11. Andrew opens and inspects his new caravan cover.
12. Covers are large and awkward, especially on a big caravan like the Adria. Andrew starts by laying it out in front of the caravan, ensuring that the ground is dry and taking care not to drag the material across the gravel. This is particularly important with the plastic window for the solar panel.
13. Lay out the cover so the smooth inner surfaces face upwards and the front of the cover is next to the front of the van. Here, you can see the rear of the cover, with the two reinforced pockets into which the extendable poles are inserted.
14. You’ll need at least two people to put a large cover like this one onto the van. Take the extending poles and insert them into the reinforced pockets.
16. Now lift the cover off the ground with the poles and walk back towards the van. Using this method, you are lifting the cover up off the ground, not dragging it over any rough or dirty surfaces, or grassy areas that are certain to stain it. Canine assistance is optional!
16. With one person on each side of the van, lift the cover up and over the roof and walk slowly towards the back of the tourer. A third person is useful at this point, to feed the cover smoothly over the front of the van, preventing it from catching on the A-frame or handles.
17. Move towards the back of the caravan, easing the cover over the roof. With a large cover, this can take a fair bit of strength. So long as you prevent the cover from getting snagged on any protrusions, it should slide over relatively easily – if you are patient!
18. It’s important to bear in mind that custom-made caravan covers are designed and manufactured to be a tight fit, because this will prevent any flapping and abrasion, which can damage painted or plastic surfaces. Pull the cover across evenly at both sides and ease it over the back panel, before pulling it down.
19. With the main cover in position, it’s time to add the A-frame cover.
20. Fit the A-frame cover to protect the caravan’s handbrake, jockey wheel and hitching mechanisms.
21. Now fit the straps. These are essential to keep the cover in place and minimise any flapping. Andrew used the extending poles to pass the straps under the Adria.
22. He also fashioned a neat device to hold the straps on to the extending poles.
23. The cover is fully fitted and strapped in place.
24. The Adria’s door remains easily accessible with the caravan cover in position.
25. The window is perfectly placed to allow the solar panel to trickle-charge the leisure battery throughout the year and keep the alarm and the tracker active.
Want to find out more about a different touring accessory? Then check out our guide to the main caravan awning manufacturers to help you find the brand for you.
Find out more:
