This new external antenna and satellite socket allows you to connect your TV to an outside TV antenna and satellite dish. You’ll need to drill four 2.5mm and one 22mm diameter holes in the side of the caravan but this product does come with comprehensive illustrated fitting instructions. A gasket forms part of the socket eliminating the need to use a sealant and wires are protected with a hinged cover.
External TV Antenna & Satellite Socket
This new external antenna and satellite socket allows you to connect your TV to an outside TV antenna and satellite dish. You'll need to drill four 2.5mm and one 22mm diameter holes in the side of the caravan but this product does come with comprehensive illustrated fitting instructions. A gasket forms part of the socket eliminating the need to use a sealant and wires are protected with a hinged cover.
